Slow Crank at Hot Starts
Old Aug 20, 2008 | 11:11 PM
whitez28133's Avatar
Default Slow Crank at Hot Starts
Just Got the car running after a year of sitting and put a new red top battery in cause i thought the battery was givin up but still at hot starts it cranks like the battery is bearly got a charge, any thoughts?
Old Aug 20, 2008 | 11:13 PM
I8ASaleen's Avatar
Sounds like the starter is going, it prolly has heatsoak.
IronOutlaw's Avatar
You need a new starter.
Old Aug 21, 2008 | 08:13 AM
leadfoot4's Avatar
While it apears that your starter is headin' south, before you spend the money, check and clean all your connections. A little corrosion, or a loose fastener, causing poor contact, will most noticibly show up when the loads are high, like when trying to crank a hot engine
Old Aug 21, 2008 | 08:43 AM
BlackScreaminMachine's Avatar
Internet Mechanic
I will say def consider the starter.
But I will say consider your CHARGING system.
I ran on my 383 a EWP from CSR connected to the 10amp KOEO and it put a serious drain in the system, Coupled w/ a Aeromotive UD pulley w/o Alternator pulley just about let the car not have enough time to recover between engine starts.
Make sure there are no draws, no UD pulley, and the alternator/starter are good units w/ in specs.
