any one with weld rims
Old Aug 23, 2008 | 08:06 PM
cruzin94's Avatar
Default any one with weld rims
i just bought 15 by 10 welds and 15/3.5 in the front and they are so tight on every thing i had to grind my breaks down so much just to get them on and now my e-brake is hittin the balance weight on the inside of the tire.....he had the rims on a ls1 so why dont they fit good on my car
Old Aug 24, 2008 | 12:47 PM
casper383's Avatar
I used 5/16 spacers on the front and ground down the calipers on the back, it took alot of grinding to make sure they cleared, about the balance weights i had them use the flat stick on weights on the I.D of the wheel since mine sees the track mostly. My e-brake barely clears the screw locks on the inner side of the wheel
Old Aug 24, 2008 | 12:50 PM
Speed Density's Avatar
hashtagBMW
I ground mine down a little bit, nothing crazy. And last time I used a spacer on the front with stock studs, I lost a wheel going 80mph.
Tony.
