Best Plug Wires?
I would go with Taylors or MSD. I run Taylors and know lots with both, no problems.
The car runs fine at normal temps, but when i sit and it gets hot like it's running temp is 180-190 and if i sit in line at strip it will get up past 200 unless i turn on a/c it stays where it was at normally (makes it turn fans on or something to make it stay cool) and cuts out at the higher temps. (cuts out as in noticeable loss of power around 5k rpms) and sometimes at running temp.. i figured i need to change plugs/wires since it's a 95 with 39k on it with stock wires/plugs, i feel like that's pretty old to have same ones in the car..
