Check out this intake manifold
Old Aug 27, 2008 | 05:51 PM
thesoundandthefury's Avatar
Default Check out this intake manifold
Think this would fit under the cowl of a 4th gen? :
Old Aug 27, 2008 | 06:00 PM
TAEnvy's Avatar
Oh MY GOODNESS.
Any info?
Id love an ITB setup, Ive always been told they really help tam ebig cams.
Old Aug 27, 2008 | 06:04 PM
Originally Posted by TAEnvy
Oh MY GOODNESS.
Any info?
Google "Extrudabody."
Old Aug 27, 2008 | 06:15 PM
TAEnvy's Avatar
Just think about that plumbed up with a direct port setup
Old Aug 27, 2008 | 07:25 PM
Formula350's Avatar
That looks like it'd have JUST enough room to fit injectors+rail in. Then again... I think the injectors go inside the top of the throttle bodies. See that hole, and then on the other side's where it's a curved part. Looks like it's set up for the BOSCH tall injectors (the new thin ones). Or is it just me?
EDIT: Nope, it's not my imagination (Switched pics, better view)
UH OH! I smell turbo lover envy >_>
Last, but not least, the kick in the pants (wallet area)
http://www.extrudabody.biz/servlet/t...sh-45mm/Detail
Products page shows $100 less than the above link, not that isn't that big of difference lol
Link to the SBC one. "Will not fit Vortec heads", pff, they clearly underestimate the power of a drill press
http://www.extrudabody.biz/servlet/t...Ram-Kit/Detail
Old Aug 27, 2008 | 07:34 PM
C5042081's Avatar
hot diggity dog
Old Aug 27, 2008 | 07:39 PM
koolaid_kid's Avatar
"Manifold not included"
Old Aug 27, 2008 | 07:57 PM
Formula350's Avatar
Check the last link in my post, it comes with that one, but it's also not cheap >_>
Old Aug 27, 2008 | 08:46 PM
Here's the entire setup a few hundred less than the list price on their website:
http://cgi.ebay.com/ebaymotors/Parts...=p4506.c0.m245
EXTRUDABODY
Chevy X-Ram ITB Kit
Package Includes, everything from the Filters to the Heads, minus the Injectors. Just add the appropriate size injectors for your HP needs and bolt it on, add your favorite Electronics, tune and go.
Package based on the Pierce X-Ram intake manifold. Extrudabody ITB's are 45mm ID taper bores that taper out to 50mm Airhorns. 45mm ID ITB's match the Manifold perfectly.
Fits all SBC except those with Vortec Heads.
Will not work with HEI "large" cap distributors.
Excellent hood clearance and looks.
TPS is included with a Mini Harness.
Set-up for standard Bosch size injectors, but rail mounts are adjustable for other size Injectors.
Foam filters are included, but Stack Filters are an Upgrade.
Throttle Cable is a center pull system and "Braided" type cables are available.
Linkage system is provided.
Old Aug 27, 2008 | 08:53 PM
This is pretty slick:
Old Aug 27, 2008 | 09:43 PM
Formula350's Avatar
Yea, I noticed some of them were longer. Pretty nifty design. But why only 3-9"? If you got more 50mm extensions... all you'd need is longer bolts. Not that you'd really need or want more, except maybe after the injector as a sort of throttle body spacer heh
Old Aug 27, 2008 | 10:52 PM
TAEnvy's Avatar
Alot of the honda guys are using modified bike setups on a cut down stock manifold.
Old Aug 28, 2008 | 12:36 AM
94m6Z28's Avatar
now that would be some yummy eye candy on a blowen V8..if only it would work/clear on an lt1
Old Aug 28, 2008 | 03:55 PM
Formula350's Avatar
I consider blowers to be the Roots/Whipple chargers and superchargers to just be the Centrifugal chargers heh Just because really the only kind back in the day (which I'm not from, but grew up learning about) were roots/whipple.
Anyways, yea, 2 pipes coming up the middle from the intercooler and then branching out to those with the "boost covers" would be pretty sweet!
Old Aug 29, 2008 | 11:10 AM
Bad_tx_Z28's Avatar
man that is pretty damn sweet...if there were a way it would work/fit ona LT1 i would be down!
