pushrods?
Old Aug 28, 2008 | 02:31 PM
stevema10631's Avatar
Default pushrods?
I have a really simple question what is the pushrod size for the CC503 cam ive herd stock but was not sure and wanted to ask
Old Aug 28, 2008 | 02:36 PM
1badzee's Avatar
It's always smart to check pushrod length
Old Aug 28, 2008 | 03:24 PM
iceman15's Avatar
stock is 7.2 but you do need to check the length. Just buy a pushrod checker like badzee suggested
Old Aug 28, 2008 | 03:26 PM
James Montigny's Avatar
The base circle and deck height remain the same.
(I'm assuming this is a stock shortblock)
Did the heads get milled? (are they even stock castings?)
Are you using stock thickness head gaskets? (.051 VS .039 Felpros or .029 GM Impala or ,026 Mr Gasket ......)
Even with a head milled .010" and .026" gasket, you should still be at 7.20 (or close enough that 7.15 doesn't help)
A pushrod length checker tool is your best bet to get the right answer.
Old Aug 29, 2008 | 10:12 AM
yea thats what i figured, they where re surfaced for reassurance (dont know how much), stock casting, but i am using the felpros ima go order one right now thanks
