Unknown LT-1 Issue
The Problem: The car starts up everytime when cold, and will run for about 10-15 minutes. After that point all hell breaks loose. Random loud *** knocks in the motor, sounds a little like misfiring/ blowing the hell up. Tach will jump around like crazy only if I touch the gas, which will also make the knocks worse. Then the motor will hiss as if it had lost all vacume and about 5 seconds later will die. If i let the car sit for approx. 10-15 min it will start up fine and run for another 10-15. Plugs, wires, and coils are fine. All vac lines are connected.
Note: One of the times this happened the motor died, however, there was an extremely loud backfire, that didn't really sound like a backfire. It was loud enough that my friend following me home, 2 cars behind me hear it, with all the windows up and music blasting.
Attempted fix's
1. It was 1k miles over due for an oil change, thought it could be a bad filter so i changed it. not results.
2. Thought it could have been bad gas. So I tried drygas and still have the same issue.
Possible issues I thought of:
1. Could it be a problem with the cooling system, stuck thermostat, or dead water pump?
2. Could it be a bad fuel filter or a dying fuel pump, or bad fuel injectors?
3. I used Seafoam about a week ago in the brake booster vac line. I heard that some people with high mileage have had issues with Seafoam eating away at gaskets, rings, and such. Anyone have any more information on this.
4. The car began leaking oil onto the driveway a bit ago and I have identified the leak as a rear main seal leak.
5. Could the Opti sensor inside the opti-spark, though not being utilized, cause a problem as bad as this?
6. Last possible issue. The motor is just tired and old and needs to be rebuilt.
If anyone has any ideas as to what it could be or could elaborate on any of the above issues that would be great.
There is a possibility that I omitted some information, if I did ill edit the post when I get home later since I'm at work.
Thanks
either way im going to fix the temp sensor tomorrow. If that doesnt solve the issue im going to replace 02's and if i still see no results im going to replace the opti sensor.
Thanks for the help ill stay updated. if anyone else has any other ideas please feel free to share.
2) Same as above, minus headers, knock sensor/module have gone nuts
3) Temp, IAT and/or O2s have taken a crap and causing the ECM to think things are way off from what they are. Probably a combination of sensors dead.
4) The EPROM is dead and going into closed loop triggers the use of it and the ECM is getting all sorts of wrong signals and doesn't know how to process them.
5) (not too sure about this one) The ECM itself is dead and is giving bad commands to the fuel injection.
Sorry, I don't know how to make this a link maybe someone can help, but I found it tooling around if you read all the way through there is a great explanation of o2 sensors and how to test them instead of blindly replacing them. Worth a look http://www.afbforums.com/forum/index...howtopic=25170
If anyone DOES have one, and doesn't need it, let me know cuz I'd like some pics of the thing with the plastic casing tore off
And yes you can desensitize the KS via tune. I'm sure who ever did your tune has a file on what was done to yours, just email them. That LT4 Knock Module does just that, just not directly through tuning.
