Lt1 Loud Knock Won't Start Banging
Old Sep 2, 2008 | 03:22 PM
str8rpn's Avatar
no metal...aparently oil doesn't go through coffee filters that well haha, used a magnet and nothing.
Old Sep 2, 2008 | 03:59 PM
fergymoto's Avatar
Pull the trans
Old Sep 2, 2008 | 04:09 PM
str8rpn's Avatar
ok i started it again...oil pressure goes over the max for the needle and it knocks and blows smoke for miles but no metal in the oil?
i started the car with the gas and clutch to the floor and it wont rev past 2k and oil pressure is of the chart?
Old Sep 2, 2008 | 04:10 PM
IllusionalTA's Avatar
call me numb nuts.... pm sent
Old Sep 2, 2008 | 07:06 PM
str8rpn's Avatar
ok its more of a popping sound from the intake?
Old Sep 2, 2008 | 08:03 PM
str8rpn's Avatar
maybe a backfire through the intake manifold?
Old Sep 3, 2008 | 12:42 PM
RyanA's Avatar
A backfire through the intake won't make your car "smoke for miles". However, a busted up ring land could take out a valve and that would cause "smoke for miles" and a backfire through the intake.
Bottom line is, if it "smokes for miles" it's "time to pull the engine"
Old Sep 3, 2008 | 12:45 PM
Fixxer99TA's Avatar
As much as I would hate to say it, but I agree with the above...
Old Sep 3, 2008 | 03:07 PM
the_merv's Avatar
Yup.. something took a ****...
Old Sep 3, 2008 | 03:53 PM
Rocky70304's Avatar
I agree, and probably would not start it and try to rev it anymore, unless you like giving money to the machine shop.... lol.
Old Sep 3, 2008 | 04:35 PM
str8rpn's Avatar
i think it was smoking because it was loading up on fuel
if it wasnt smoking what would cause a popping in the intake?
opti?
Old Sep 3, 2008 | 05:11 PM
  #32
AChotrod's Avatar
Sounds blown up to me. I hope not for your sake though!
Old Sep 3, 2008 | 05:19 PM
  #33
str8rpn's Avatar
thanks guy...since your so smart what is "blown"
Old Sep 3, 2008 | 05:25 PM
  #34
AChotrod's Avatar
Spun a bearing, blew a piston snagged a ring, etc.
My buddys clutch was so tight it was putting consant strain on the motor. So much, the one day he got on it hard it Blew the crank, took out the block, water pump, crank, pistons, rods, valves etc. Basicly Blown up like a gernade. The clutch had only been installed for less than 100 miles and when we pulled the trans the NEW clutch was toasted in that short time.
Old Sep 14, 2008 | 06:54 PM
  #35
Blue-Z's Avatar
Str8rpn, you prob have bad luck because you couldnt refund me my $75 for the broken fog lights you sent me. Good luck buddy
