killed it
Old Sep 1, 2008 | 08:23 PM
97lt1z28's Avatar
Default killed it
well after a really long time of frustraion i tore the motor out and discovered i had spun all the rod bearings and two of the the crank bearings. Believe it or not i had oil pressure for about 5 min then it would start to fail and on top of that no knock. so know i need to decide wether to rebuild this or change over to a old school 350. if i rebuild i will go 355 forged pistons reground and polished crank and trued up stock rodswith a bigger cam to compliment the LE2 heads. if not ill go old school. still a small block but with out the opti and tuning frustrations of a new LT1. Any one have any suggestions or recommendations. i can rebuild what i got for roughly 2 grand. Had anyone put a older style motor in thier cars. Do the headers fit, or is it worth it to stick with the LT1. Let it be known this will be a track car. I appreciate suggestions on everything from converting my motor toa carb and standard dist to swaping to keeping what i got as long as it stays within the 2-3 grand range. Thanks
Old Sep 1, 2008 | 08:27 PM
the_merv's Avatar
Veteran: Air Force
How did the Engine fail..as in what were you doing at the time..
Old Sep 2, 2008 | 02:48 AM
3pnt4maro's Avatar
I spun my main bearing and had great oil pressure and still drove..just a slight knock...noticeable loss in power though and every now and then a drop in pressure...
I say rebuild it..its what I did and there is nothing like hearing that LT1 turn over for the first time..prob save you some headache as well...the 350 old school is a lil bit of a headache to get in these cars...can be done..but just a headache in my opinion
Old Sep 2, 2008 | 04:41 PM
97lt1z28's Avatar
Anyone have any info on converting what i got to a standard dist and carb using lt1 heads. This info would be great!
Old Sep 2, 2008 | 05:07 PM
AChotrod's Avatar
If you go old school your starting all over as in from scratch unless you already got everything Heads,Intakes porting, carbs etc! Rebuilt into a forged 355. It would be cheaper
