Oil pressure questions..
Thanks,
- Mike
the previouse owner could have used some heavier weight oil to thickin it up and bump up oil pressure for the sale. Who knows.
How many miles are on the engine? What temp does it run at.
Also the gauges on these cars are unreliable (So I hear). hook up as master gauge or a mechanical gauge to see whats really going on.
That is with 10w-40 valvoline premium conventional and an AC Delco filter.I had higher oil pressure with 10w-40 valvoline max life synthetic blend at operating temps,but I think that was because I overfilled it a little bit with that stuff
.I went back to dino oil cause synthetic likes to seap through my gaskets
Thanks,
- Mike
ALSO JUST FOR REFERENCE MY MECHANIC TOLD ME A SAFE WAY TO CHECK YOUR OIL PRESSURE IS TO MAKE SURE YOU HAVE 1 PSI OF OIL PRESSURE PER 100 RPMS.
SO AT SAY 800RPMS YOU SHOULD HAVE NEAR 8 PSI OF OIL PRESSURE.
So don't worry about that oil pressure
Lots of people here prefer the European 0W-20 if they can find it. Everything I thought I knew about oil weights and those numbers, went out the window when I came here heh. So don't worry about that oil pressure
- Mike
but in all seriousness mine does jump around too and i always wondered if it was bad, but now i guess i know its all gravy! haha and mine jumps like 5-6 psi pretty regularily.
