Header bolts: A correction
Old Sep 6, 2008 | 01:53 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Default Header bolts: A correction
In the past, I’ve had good experience using the 3/8 X 1 inch intake manifold bolt kit from Spectre Performance available in various places such as Auto Zone for like eight bucks, with a wrench.
I said these were great bolts and as good as much more expensive bolts on the market. It was as much about ease of finding and purchasing them as well as the cost.
I’ve noticed a reason to not use them for header applications and I wanted to post this "correction" here.
I’ve had these bolts in use as header bolts for about two years now. With time and cyclic heating/cooling, the points of the 12 point heads have seemed to rounded off from corrosion or some other effect. It looks like after enough time, a wrench might spin on them making them impossible to remove. This would obviously be a huge problem. Just for the record, they’ve never loosened, not a one.
I hate stainless hardware. It’s soft, easy to strip and gall, may cause galvanic actions with other materials and isn’t the strongest fastener. I stay away from using stainless fasteners anywhere.
This is an instance where stainless steel bolts would be better than steel. I’m changing my header bolts over to ARP 400-1211 bolts. Just like the Spectre bolts, they’re one inch UHL and will go into the head deep enough to resist loosening up. Wrench not included.
These will be the only stainless fasteners on my car.
Old Sep 6, 2008 | 01:57 PM
fergymoto's Avatar
I have been running those ARP header bolts you are switching to for 3 years. They have been on and off many times. They never come loose on their own. I like them
Old Sep 6, 2008 | 02:35 PM
hyperzone's Avatar
good to know.. I actually remember your other thread about those spectre bolts and thought about checking that out eventually. thanks for the update. You still think the copper gaskets are a good investment? I've heard mention of aluminum 'crush type' header gaskets recently and didn't know they made that for the LT1. making me curious.
Old Sep 6, 2008 | 03:57 PM
fergymoto's Avatar
I like the aluminum Percy's gaskets. I've reused them a lot and they never leak
Old Sep 6, 2008 | 06:49 PM
Paul Bell's Avatar
I'm running the SCE copper gaskets and they do well, re-used them once so far.
