yank 3600 with a 100 shot
Old Sep 8, 2008 | 09:05 PM
cruzin94's Avatar
Default yank 3600 with a 100 shot
i was wondering how my 3600 stall would work with nitrous because i know they make nitrous stalls and every thing so is any one running a set up like this
Old Sep 8, 2008 | 09:26 PM
LS1 SPEED's Avatar
which model?
Yank also has a pretty good info section for basic mods and suggested converters or you can always give Dave a shout
Old Sep 8, 2008 | 10:18 PM
Puck's Avatar
A 100 shot is small, and will not need a special stall .
Old Sep 8, 2008 | 10:24 PM
StealthFormula's Avatar
Should be good depends on shift rpm tho...nitrous will boost the shift extension so if your at stock shiftpoints which are 5600? correct me if Im wrong, the shift extension of the SS3600 w/ 3.73's ~4900rpm would be too close to work right. Yank wanted me to go with the SS4000 all motor with 6400 shiftpoints. When I told them I wanted to spray the car they told me to go with the SS3600 because the shift extension would be too close to my shiftpoints on the juice. In terms of strength it will be fine with a 100 shot but I would call up Yank to see if the shift extension would be too close to where you shift on the nitrous.
