replaced opti, coil, and ignition mod. what else?
are there any other problem parts/areas i should be looking at on these cars? got just over 140k miles on the bird.
i feel like a friggin newb again with this car. i open the hood and i'm lucky to be able to check the oil and top off the wiper fluid in a timely manner.
(probly shoulda mentioned that I just purchased the car 2 weeks ago)
*edit* water pump was replaced by previous owner. I just wish he'd gone ahead and done the opti at the same time, woulda kept me from getting stranded on the side of the interstate.
How are you on trans/rear end/PS fluids and coolant? Any records?
You cant really check the level, but you might get lucky if you pop off the fill plug and can see inside (if that angle is even possible, hahaha).
