Tune
Not sure how the PCMs layout is, and what tables are available, but Volumetric Efficiency is what I change and notice quite a response from my car. If your car breathes better, the VE will go up. Depending on what all you have for bolt ons, will depend on how much you want to change it.
While it seems like a really stupid way to tune, I actually use Desktop Dyno. I've made an LT1 that's pretty much right on the nuts for specs, just a few tweaks had to be made to get that though. Either way, the VE is still helps, even if it's not accurate as to what the motor is making in reality. Since the gains to enter in, vs the change that happens, gives you a fair idea of how much to adjust your VE in the PCM.
There's also timing and Air Fuel Ration, but neither I know anything that can help you, other than adjusting the AF/R to around 13.5 to get more power.
Here's a link to a page that might help some.
http://www.ssz28.com/tech/Scanmaster.html
