need help
Old Sep 13, 2008 | 02:21 PM
snk-huntr's Avatar
Default need help
how do i check a rearend to see if its positive traction or limited slip i have the cover off but dont know what to look for?
Old Sep 13, 2008 | 02:40 PM
Elliott's94Z's Avatar
I take it you have the stock rearend right?? Never been changed out? If so you more then like have limited slip. Have you ever done a burn out and had one tire spin while the other just sat there? If so, you have limited slip.
Old Sep 13, 2008 | 03:05 PM
the_merv's Avatar
The Auburns have the Center Plates with the 5 Springs in their Posi's. The Torsens are all Gears I believe, they are a little tougher.
Old Sep 13, 2008 | 03:34 PM
snk-huntr's Avatar
i just got the rearend to replace mine but it has drum brakes and i was told it may have come out of a v6 95 camaro were the v6 cars posi or slip and how can i check?
Old Sep 13, 2008 | 04:57 PM
the_merv's Avatar
V6 Cars were open rear I beleive.. not even a Limited Slip..
You basically just got a housing, weld it or get a good one.
