plz identify this module... abs computer?
Old Sep 13, 2008 | 09:12 PM
InsaneAuto86's Avatar
Default plz identify this module... abs computer?
What is this....? It was under the dash, to the left of the steering shaft.
Is this the windshield wiper motor? Also buried in the dash area...
Old Sep 14, 2008 | 08:19 AM
I typed the part # in GM parts direct, hit to "MODULE AS $5xx.00..."
Anyone?
Old Sep 14, 2008 | 06:44 PM
jester1614's Avatar
not sure what it is but i have one if you need one....mine is out of a 95 as well.
Old Sep 14, 2008 | 07:31 PM
I8ASaleen's Avatar
body control module.
Old Sep 14, 2008 | 07:49 PM
So I need that thing? Car seemed to run fine without it...
Old Sep 14, 2008 | 09:15 PM
FICINJECTORS's Avatar
gauges, odometer, headlights, things like that are controlled via the BCM.
Surprised it ran tho, it should be storing the VATS code too
Old Sep 14, 2008 | 09:56 PM
RyanA's Avatar
That is the ABS module. If your car has traction control, it's the ABS and traction control module. Body control module is located on the passenger side near the glove box.
Old Sep 14, 2008 | 10:03 PM
I8ASaleen's Avatar
It should be the BCM if it's under the driver's side, maybe mine is different b/c it's a 97
Old Sep 15, 2008 | 04:13 AM
no traction control...
Old Sep 15, 2008 | 07:18 AM
RyanA's Avatar
Still ABS computer. That box either has ABS or ABS/Traction control. There were NO body control modules that came in metal cases on F bodies. Body control modules have ALWAYS come in the black plastic "clamshell" style case and they have ALWAYS been on the passenger side on an F body.
It's the ABS module no matter how you slice it....
Last, 1995 Camaros don't even have a BCM. They only have a keyless entry module that is located in the passenger side kick panel.
Old Sep 15, 2008 | 09:04 AM
Thank you very much for the info!
