Shift Points
Old Sep 15, 2008 | 04:34 AM
JOSH13's Avatar
Default Shift Points
Well I started tuning and realised how low my car has been shifting . For 1 I just tried using Datamaster to log a run and saw that my highest shift was 1 to 2 and it was only at 5,825 RPM's . I'm kind of curious what the LT1 is capable of shifting at stock and what area is best ? My cars an auto and I rose that shift by 2 MPH and it was that low so stock must have been even a little lower lol .... It just seems like that being my highest RPM is kind of low ....
Old Sep 15, 2008 | 04:41 AM
BlackTTC6's Avatar
You'll get valve float above 5800rpm if i'm not mistaken on an LT1 with stock valvetrain.
Old Sep 15, 2008 | 04:44 AM
JOSH13's Avatar
Hmm .... Kind of makes sense . It is an auto Corvette and my tach does go to 6 . I thought that 6000 RPM's atleast would be safe without float . If that's the case where is the only weakness the springs ?
Old Sep 15, 2008 | 04:48 AM
BlackTTC6's Avatar
There's no real reason to even rev that high with the stock cam. The Stock cam will drop power substantially after it's 5200rpm peak.
Old Sep 15, 2008 | 04:51 AM
JOSH13's Avatar
The Stock cam will drop power substantially after it's 5200rpm peak.[/QUOTE]
My car is running the stock cam and even on stock tune pulls higher than that and is pulling at its hardest in that range ....
Old Sep 15, 2008 | 04:55 AM
BlackTTC6's Avatar
Look at the graph i posted above. It tells the whole story.
Old Sep 15, 2008 | 05:13 AM
JOSH13's Avatar
Weird .... I looked at datamaster dyno graphs which I know aren't all that accurate but my HP continued to rise until past 5500 and torque leveled off some there . I guess Ill have to go to a real dyno sometime to see what really happens there . I just assumed that atleast the m6 guys would be pulling a little higher than that .
Old Sep 15, 2008 | 01:48 PM
JOSH13's Avatar
Anyone else have any experience or input on the LT1 shift points ?
Old Sep 16, 2008 | 12:51 PM
JOSH13's Avatar
Where are all of you bolt on guys shifting at ?
