need some things answerd on the eagle kits..
Old Sep 18, 2008 | 01:54 PM
$O$OE's Avatar
Default need some things answerd on the eagle kits..
I was wondering what is the difference between a 2PC rear seal kit and a 1PC rear seal kit?? and which of these kits will be good for a 355or383. im debating which one to choose from, i plan on running the motor with N2O so i dont know if i should just stick witht he 355 and add a pair of some good AFRs and a good cam...
here is the link to the eagle kits:
http://www.eaglerod.com/products/Che...ssemblies.html
Old Sep 18, 2008 | 01:57 PM
$O$OE's Avatar
and by the way its gonna be a street car with full bolt-ons and suspension....i just think i can go with the 355 and run n20 with full bolt-ons and good suspension and rip some A*holes out in the streets.. and if the both kits come about the same price i might as well go with the 383?
Old Sep 18, 2008 | 02:01 PM
danhr's Avatar
go 383
and the 2 pc rear main seal is the older SBC. you have a nwewer one, so you want a 1 piece.
and i'd go w/ a 383.... leaves you more open to options
Old Sep 18, 2008 | 02:05 PM
$O$OE's Avatar
and whne u say leaves me more open options what do u mean about that?
$O$OE's Avatar
can a 383 breath good with the stock heads but ported??
Old Sep 18, 2008 | 02:08 PM
Purple95Z28's Avatar
Some of the fastest LT1s out there run ported stock heads, but they have to be done by someone who really knows their way around those heads.
Also the Eagle kits are not really worth it unless you get the all-forged assemblies, their cast cranks are not even as good as the stock ones.
Old Sep 18, 2008 | 02:13 PM
$O$OE's Avatar
so what kit should i get besides eagle?
Old Sep 18, 2008 | 02:18 PM
$O$OE's Avatar
and also what rod lenght should be used on a 383, a 6.000'' or 5.700''
Old Sep 18, 2008 | 02:22 PM
letsrun97z's Avatar
6.0 and the block will have to be clearanced for it.. Scat mkes some good kits
you can use stock crak and rods just get some good pistons and rings
Old Sep 18, 2008 | 02:33 PM
fergymoto's Avatar
Talk to an engine builder. There is one post with accurate info so far in this thread.
Old Sep 18, 2008 | 02:37 PM
$O$OE's Avatar
so im guessing i should stick to the 5.7'' rods then. i hav not looked into the scat kits yet..but will..
Old Sep 18, 2008 | 02:39 PM
$O$OE's Avatar
so u think i should keep the stock crank and rods and get good pistons that macth the 383 bore..how much can those cranks handle?
Old Sep 18, 2008 | 03:27 PM
$O$OE's Avatar
this kit any better than the eagle one?
http://www.jegs.com/i/Scat/942/1-40760BI/10002/-1
Old Sep 18, 2008 | 04:31 PM
connexion2005's Avatar
Scat makes comparable pieces to Eagle but it is rumored that they have slightly better QC although I don't know if that is proven.
Old Sep 18, 2008 | 11:47 PM
$O$OE's Avatar
i think im gonna go with the scat kit on jegs.
