Help Please. ;/
Old Sep 20, 2008 | 12:09 AM
strokin93z's Avatar
Default Help Please. ;/
i decided to take the battery out for other reasons, went to put it back in and the damn thing wont do anything, no power... so im thinking, okay loose cable. check everything, everything checks out fine and still nothing. i jumped the car finally got it running... i let it idle for about 5 minutes. backed out the drive way, put in drive, and the emergency brake light flashed rapidly then all power was gone after about 10 secs in drive. I rejumped the car, and did the same again... i dont know what to do
Old Sep 20, 2008 | 12:58 AM
chavez885's Avatar
New battery...?
Old Sep 20, 2008 | 01:01 AM
strokin93z's Avatar
i thought maybe the security?
Old Sep 20, 2008 | 01:10 AM
jarretthise's Avatar
is your security light staying on??
Old Sep 20, 2008 | 01:16 AM
strokin93z's Avatar
it was on for 2 years before then, and never would go off... ive had the battery in and out plenty of times since then... i would want to think a new battery but the car ran fine in park, getting good charge and alll...
Old Sep 20, 2008 | 01:23 AM
well there is a resistor in your key and that has a special ohm reading on it that sends that amount of ohms to your bcm which then sends the signal to your computer...that resistor might be bad...go to the gm dealer and get another key made( they will need your title and license).. do you only have one key for the car or multiple?? if this doesnt do the trick then we will look for other things...
Old Sep 20, 2008 | 01:27 AM
strokin93z's Avatar
i love to say the key, but i get a new key probably a year ago. trying to get rid of the security light. lol..
Old Sep 20, 2008 | 02:12 AM
BigZee71's Avatar
If it will start off of a jump, then I bet the VATS has nothing to do with it.
 Michael S. Palmer
Old Sep 20, 2008 | 02:17 AM
ok well do you know how good your opti is?? optis can make your car do some weird stuff man.....and not necessarily true, it can still be your VATS even know its running....it wont stay running in gear but it will run in nuetral...sounds like a THEFT issue kinda thing there huh?
Old Sep 20, 2008 | 02:19 AM
have speartech flash your vats in your computer....its a bypass...that might take care of your security light...and also if your light is on right there you know you have issues with your sec system....dead give away...that light just doesnt come on for any reason...is your service engine soon light coming on?
Old Sep 20, 2008 | 03:33 AM
strokin93z's Avatar
nothing out the norm is happenin till the car is in gear, then the brake light flashes...
Old Sep 20, 2008 | 07:56 AM
to be completely honest it sounds like a VATS problem man...call speartech and talk to them about it...they can tell you if your computer or bcm can make it do the things you are talking about...they are good with pcms and stuff of that nature
Old Sep 20, 2008 | 02:36 PM
strokin93z's Avatar
im going to go out and try to take the battery out for a little see anything happens.
Old Sep 20, 2008 | 02:50 PM
Formula350's Avatar
Well, you have a 93 I see, and most people I think are recommending something that isn't as easy on a 93. Simply because, we have no BCM, OR PCM for that matter. We have the old school ECM and things are different with that. Oddly, my security light never comes on, and I'm not sure why >_> I know we have different F-Bodies, but do you have a small light on the left side of the steering wheel on the dash? It would be a red LED. I have one on mine, and I'd say aftermarket, except it has a molded ring around it that's molded into the plastic dash, so definitely a factory item for me.
Alternatively you can jump the ALDL port pins and get the check engine light flashing to see if there are any codes present. If by some odd chance you live in Minnesota, I can swing by and check it (codes and operational data) for you heh
Unless the key was in the ignition and turn forward some, when you reconnected the battery, I don't feel it'd be the key. I only mention that due to a possible instant surge, and just enough to tweak that resistor to put out just a slightly different Ohmage (hah I love making up words).
www.shbox.com if you don't know about it.
Here's how to jump the pins, also if you don't know how.
http://shbox.com/1/dlc2.jpg
Old Sep 20, 2008 | 03:33 PM
strokin93z's Avatar
no i dont have the red LED. right now i am too far away from the car to work on it. but ill be back to mess around with it, and let u guys know if anything new happens.
Old Sep 20, 2008 | 08:33 PM
C5042081's Avatar
once I had a bad terminal bolt, the car would jump start but would not start without the jump
Old Sep 21, 2008 | 01:58 AM
strokin93z's Avatar
Got the car started! cables were not on tight enough? i literary put 100ilbs on them, and it started straight up... happy that i got the car running again, but pissed it was something that simple...
Old Sep 21, 2008 | 05:34 AM
good job man....i woulda said that but you made it sound reasuring that you had done that already and i didnt realize it was a 93 so lol....you couldnt have done a thing with the bcm cuz there is no bcm haha
