Injector size
Old Sep 20, 2008 | 08:57 PM
Dmaleck's Avatar
Default Injector size
Was wondering what size stock injectors are for an 96 lt1 and also how can you tell if you have aftermarket injectors and what size they are, thanks!!
Old Sep 20, 2008 | 09:40 PM
SCott5's Avatar
they came with 24 lbs stock
Old Sep 21, 2008 | 12:16 AM
19mike84's Avatar
from what i understand all lt1's came with 24's except 93's which have 22's?
Old Sep 21, 2008 | 12:36 AM
Formula350's Avatar
Correct.
Stock injectors are black tops with a silver-ish band in the middle. Anything aftermarket is basically not going to look like that (not saying it can't, just not likely).
Old Sep 21, 2008 | 11:16 AM
Dmaleck's Avatar
Thanks for the help. So lets say i have aftermarket injectors...is there anyway of finding out what they are?
Old Sep 21, 2008 | 11:46 AM
Formula350's Avatar
Sure! Pull one out and write down the numbers that are on the plastic (on the top) where the plug in goes.
