strong chassis
Old Sep 22, 2008 | 04:48 PM
fast414's Avatar
Default strong chassis
hi there just wondering how to make my chassis stronger say like mid 10's. i also had about 3 spots repaired on the floor does that make it any weaker) properly repaired , does not leak at all, floors or body). not really into a cage. thanks matt
Old Sep 22, 2008 | 06:39 PM
z28rob18's Avatar
subframe connectors, strut tower brace
Old Sep 22, 2008 | 06:43 PM
Formula350's Avatar
Could go the extra mile as well and put in a rear shock tower brace, as well as doing what I saw for a third-gen. Bear with me on this explanation: What it is, is a bar that is bend to the contours of the rear floor and then it bolts to the inside of the door-sill. It's like a mid-chassis brace like the strut tower.
However, I believe that no track will let you run w/o a cage. And a cage will really stiffen things up for you.
Old Sep 22, 2008 | 06:51 PM
z28rob18's Avatar
also a tunnel brace
