18 Degree Heads
Old Sep 26, 2008 | 12:34 AM
LT1_4_Life's Avatar
Default 18 Degree Heads
Does anyone make 18 degree heads for the LT-1?
Old Sep 26, 2008 | 08:29 AM
TwoFast4Lv's Avatar
No you have to get them converted. A few have done it. I have a set of heads but do not have them converted yet
Old Sep 26, 2008 | 11:57 AM
LT1_4_Life's Avatar
What is involved in the conversion, and what is a good brand of 18 degree heads to get?
Old Sep 26, 2008 | 05:23 PM
LT1_4_Life's Avatar
Anyone?
Old Sep 26, 2008 | 05:38 PM
96capricemgr's Avatar
Are you certain this is what you need??
You know 23degree LT1 heads, GM and aftermarket are capable of 9s NA
Old Sep 26, 2008 | 08:38 PM
LittleRedZ's Avatar
18 degree intake, and valve train, custom headers $$$$$$$$$$, if you going to spend the $$$$ either do SBC2.2 or Little CHief 11 degree heads
Old Sep 26, 2008 | 10:07 PM
LT1_4_Life's Avatar
Just exploring ideas... want to know what is involved
little chief 11's... got it
Old Sep 26, 2008 | 11:02 PM
TwoFast4Lv's Avatar
It is definately expensive and easily 100hp more then any other LTx combo I have seen short of 2.2s
Old Sep 27, 2008 | 01:57 PM
z282c4's Avatar
Brodix makes a 18deg head with 23deg exhaust ports for standard 23deg headers....STD18x from brodix..
Old Sep 27, 2008 | 10:09 PM
toby's Avatar
edelbrock makes the best 18 degree castings. darts are also good, but stay away from brodix.
Old Sep 28, 2008 | 12:38 AM
z28matt's Avatar
yeah I've heard bad things about brodix
Old Sep 28, 2008 | 12:02 PM
TwoFast4Lv's Avatar
Actually it is just the 18X heads that suck
Old Sep 28, 2008 | 02:50 PM
1989GTA's Avatar
So what brand of 18 degree heads are we talking about? All the ones I have seen have runners to big for what I would call a street car. I'm interested myself.
I have heard the same regarding the Bodix 18 degree head. Better off with say the AFR.
Old Sep 28, 2008 | 03:20 PM
Abdullah's Avatar
i would go with the 9:1 compression GM performance parts 18* heads. they have 215cc intake runner heads unported, 60cc chambers and 0.080" deck height beside you can use stock headers with these GM 18* heads.
MindGame in www.camaroz28.com forums used the GM 15* heads (derived from the GM 18* heads) with modified GM LT4 intake manifold and did
540rwhp NA in a 383ci LT1 camaro but they have smaller combusion chamber of 48cc.
Old Sep 28, 2008 | 04:50 PM
jarretthise's Avatar
you know LE and AI make some good stuff.....i would give them both a call....you might change your mind about going with what you want right now....our cars are capable to run 9s with 23 degree heads...why would you go through all the trouble to convert everything
Old Sep 28, 2008 | 05:23 PM
kinglt-1's Avatar
Maybe he wants to run 8's?
Old Sep 28, 2008 | 05:50 PM
FASTFATBOY's Avatar
The better the heads, the less cam needed
Old Sep 28, 2008 | 06:26 PM
then add a turbo or nos or something...thats N/A running 9s
Old Sep 28, 2008 | 06:30 PM
z282c4's Avatar
what about the brodix suck? has anyone tested them, i think they came out last year maybe.
Old Sep 28, 2008 | 08:38 PM
TwoFast4Lv's Avatar
Some of us definately do
To build the 18x they cripped the side width of the port section. They are much more limited then the true 18* heads but are cheaper to use because they use standard rockers
