bbk underdrive pulley question
Old Sep 26, 2008 | 05:41 PM
shutzero's Avatar
Default bbk underdrive pulley question
so i installed this about a month ago and my alternator charges are like really low. understandably this is to happen when installing the bbk underdrive pulley as that is what it is supposed to do, but is there anyway to get my charges back up to normal by keeping this on?
Old Sep 26, 2008 | 05:52 PM
Formula350's Avatar
Sure, get the alternator pulley For our cars it would be a 2 piece underdrive kit, crank and alternator. Older, and non LT cars, would be a 3 piece being the crank, alt and water pump. Most vehicles get the power gain from the reduction due to the drag on the water pump, not the alternator. So in reality, on our cars there's not much of a reason to get one except the benefit of having less rotating mass on the crank. Ideally, you'd get a hub+underdrive all-in-one, which frees up even more rotating mass.
Basically, you need this guy
http://store.summitracing.com/partde...5&autoview=sku
(If you can still, return that BBK and get that one, $68 is the BBK through summit, and $75 for the 2 piece!)
Old Sep 28, 2008 | 06:03 PM
jarretthise's Avatar
march sells a good set too....i have them on my car and i have no complaints
