Starter Help?
Old Sep 27, 2008 | 10:46 AM
LT1PwrdZ's Avatar
Default Starter Help?
Guys just finshed dropin the fresh build in the car and its almost time to fire up. On the starter, Is there 2 small wires on the little post and then the main cable. or only one little wire. I Have the main cable and one small wire on the solenoid hooked up but i thought there was 2 little ones, anyone confirm that for me? Thanks
Old Sep 27, 2008 | 11:07 AM
the_merv's Avatar
Veteran: Air Force
Usually it 2 large bolts, and one small one in the Middle. One of the large ones will have a wire on it going to the Starter Unit, so the other one is where the Positive goes.
The little bolt is where the Purple Starter Wire from the Harness goes.
Old Sep 27, 2008 | 11:23 AM
fergymoto's Avatar
You got the purple wire that goes to the small terminal and the B+ wire that goes to the B+ terminal. If you are confused about the small black wire down there, it is supposed to be grounded to the block by the oil dipstick.
Old Sep 27, 2008 | 11:31 AM
LT1PwrdZ's Avatar
i might have it back word. Thanks i will check it out now
