Last blot...stripped
Old Sep 27, 2008 | 11:35 AM
dante1313's Avatar
Default Last blot...stripped
last header bolt stripped on the passenger side.
2ed front the front. it is stripped..how do i get this out??
Old Sep 27, 2008 | 11:40 AM
the_merv's Avatar
Veteran: Air Force
Is the Head of the Bolt stripped? Are you in the process of installing Headers and you are taking off the Manifolds right now?
Old Sep 27, 2008 | 11:41 AM
fergymoto's Avatar
Try 9/16 and 14mm 12 point and 6 point sockets, see if any fit tight and if they do try to pound them on straight as possible. You may be able to grab it like that. If not, Sears sells some pretty good bolt removal tools.
Old Sep 27, 2008 | 11:46 AM
the_merv's Avatar
Veteran: Air Force
I had some of the Pacesetters strip on me. I was able to carefully grind the Heads of them down with the Dremel, and then got the Header to move a little and popped what was left of the bolt right off. Then I took the Header off and removed what was left of the Bolt. The fcked up thing about it is that it came right out by hand..
See if that will work for you. If you can't turn it by hand, Vise Grips will work.
Old Sep 27, 2008 | 11:55 AM
dante1313's Avatar
yea...
dante1313's Avatar
thx guys ill try.
Old Sep 27, 2008 | 12:00 PM
the_merv's Avatar
Veteran: Air Force
^^Yea.. try what he said first. If that doesn't work, mine definatley will. Grinding **** always works a hell of alot better, you don't even have to really worry about fckn up the Manifolds either.
Old Sep 27, 2008 | 12:03 PM
phirepower's Avatar
If not retap the threads and use the stuck bolt as a stud. thats what i did
 Michael S. Palmer
Old Sep 27, 2008 | 12:07 PM
the_merv's Avatar
Veteran: Air Force
The front one on the Passenger side is pretty much a Stud.. I'm pretty sure that is the one that the Alternator Bracket goes on..
Old Sep 27, 2008 | 01:54 PM
dante1313's Avatar
well i got the header off. thanks for everyone's input.
Auto zone sold me this piece that took it off.
now that the header is off, however how am i supposed to get it in?
I took of the starter and dip stick. do i need a lift? to lift my car?
Old Sep 27, 2008 | 02:29 PM
fergymoto's Avatar
You need to put the car up on jackstands about a foot and a half off the ground and they should slide right up in from the bottom.
Old Sep 27, 2008 | 03:39 PM
the_merv's Avatar
Veteran: Air Force
He might have to jack up a side of the Engine a little bit..unbolt one of the Motor Mounts, and jack that side up.
Old Sep 27, 2008 | 03:59 PM
fergymoto's Avatar
That's always possible depending on how consistent Pacesetter is with their manufacturing. I have installed two sets and both went right up in.
