Ground Wire Help
Old Sep 27, 2008 | 11:50 AM
LT1PwrdZ's Avatar
Default Ground Wire Help
Guys, Starter was hooked up correctly. The purple wire was to solenoid and black wire was block ground,
The starter doesnt make a sound, Bad starter maybe, i took it off a couple months ago. Is there a ground wire that comes off the driver side harness by the coil. i have 3 wires there with no end? maybe a ring terminal ground broke?
Old Sep 27, 2008 | 11:53 AM
the_merv's Avatar
There are 2 Black wires, one to the block and one on the Starter. Make sure that you don't have the Negative wire on the Starter..check it all the way to the Terminals if you have to.
Old Sep 27, 2008 | 01:02 PM
fergymoto's Avatar
That's your problem. Those are grounds and yes there is supposed to be a ring terminal on them.
Old Sep 27, 2008 | 01:04 PM
the_merv's Avatar
^^I missed that part.. it didn't show up..
Yea.. that might be your problem bro.
Old Sep 27, 2008 | 04:50 PM
LT1PwrdZ's Avatar
Fixed car started and runs good, time for the N20
