help?
Old Oct 3, 2008 | 02:34 PM
94Dailyz28's Avatar
Default help?
Ticking noise from by where the intake is. sounds like a fap fap fap fap fap. Every second or so, it's pretty loud. Fixing intake should fix that noise right?
I also get misfires some times but that should be fixed with a tune up.
Once i get into 90mph and higher seems like my car struggles to go faster, hope it's just trans cause i plan on getting one from performabuilt or FLT real soon anyway.
Old Oct 3, 2008 | 02:42 PM
the_merv's Avatar
Veteran: Air Force
You sure that noise isn't coming from around the Exhaust Manifolds, or in that area..
Old Oct 3, 2008 | 03:10 PM
94Dailyz28's Avatar
Well i know it's at the front, on the right side of the engine. What could it be? I sure do notice my exhaust doesn't sound like it did when i first got the car.
Also anyone know where i can get some window motors? Both sides , also my power locks don't work. Tried to have a shop look at it and see why he said "Have to fix both motors before i can see" Is that true?
Edit: Yeah my car is a mess, but I don't care i'm going to fix my baby up all the way.
Old Oct 3, 2008 | 03:24 PM
the_merv's Avatar
Veteran: Air Force
Sounds like an Exhaust Leak..
Old Oct 3, 2008 | 04:52 PM
94Dailyz28's Avatar
Do you know how much i could be looking to spend?
I'm not trying to get ripped off
Old Oct 3, 2008 | 08:21 PM
jarretthise's Avatar
well most shops will fix them up to the header/ exhaust manifold....get up to where the header/ exhaust manifold bolts to the motor your gonna have to find a shop or do it yourself...gaskets are like 10-40depending on how good of ones you get....a shop shouldnt be too outragous i wouldnt think
