Fuel Line Question, is one a breather/vent?
Old Oct 5, 2008 | 04:21 PM
Cross's Avatar
Default Fuel Line Question, is one a breather/vent?
Ok so of the three lines marked fuel when putting the motor back in with all the Air/EGR gone I have an extra line out of those three... and it seems to be a vent/vacuum. Could someone confirm this for me before I bring it back into the system with a Vacuum T?
Old Oct 5, 2008 | 04:42 PM
kierstyn's Avatar
I could be wrong but I think one of them goes to the charcol canister and is a vent like you said!
Old Oct 5, 2008 | 04:46 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
That's the EVAP line. You can pull it off and just plug the line that runs from the rear of the car.
Old Oct 5, 2008 | 06:13 PM
Cross's Avatar
Alright well I have to T in the PCV now too so I will just include it *Shrugs* why not... even with all this EGR removed, the wire tuck, AIR removed and everything else I have pulled off I still think the engine bay looks to busy...
Old Oct 5, 2008 | 09:06 PM
OWN3D BY MY PROF!
^ Yeah, there's a ton of crap in the LT1 engine bays. It took me 10x longer to pull the intake manifold off of my 93 compared to my LS1 Formula.
Old Oct 5, 2008 | 09:17 PM
Cross's Avatar
I have pulled out so much crap tucked wires.... it just never ends... Next I will relocate the Battery, the Heater Hoses are gone but I still need to do more...
I want to hide the Power Steering Res.... then the fuel lines moved... I still don't think it will ever get clean though.
Old Oct 6, 2008 | 09:26 AM
OWN3D BY MY PROF!
^ If you search LALT1 he did a write up on how he used a power steering pump from some other car with a built in resevoir. It was mounted on the driver's side and looked a lot better.
