LT1 swap,,,
Old Oct 8, 2008 | 10:31 AM
Formula350's Avatar
Originally Posted by the_merv
I'd still stick with the Manual..anyday. I'm sick of having an Auto, it keeps fckn breaking..
Atleast I know that if I smooth shift my new T56 and cruise it, it will last forever..and I can actually take the thing on a 2+hr drive without worrying about it breaking.
Why don't you use that T-6060 I mentioned once (and started a thread about)? The one in the Supercharged LS3 ZR1 car can handle 620ft/lbs. MH3 is it's TRPO (Trans RPO?) code and it only came in the ZR1. Otherwise the CTS-V can do 560ft/lbs with RPO (also an exclusive trans).
Picture for the CTS-V version
Picture for the ZR1 version
As you can tell, if you used the ZR1 version, you'd need to get the CTS-V's bell and tail shaft housings. Here's the MG9 (CTS-V) spec sheet and the MH3 (ZR1) spec sheet
Alternatively, for the 07 T56 MM6 RPO(Specs and Pic) handles 470ft/lbs. (06, and some 07 models like for ZR1 and CTS-V only handle 400ft/lbs, which is why I'm giving RPO codes).
Old Oct 8, 2008 | 11:22 AM
the_merv's Avatar
The one I'm getting is Guaranteed with a 1yr Warranty to hold 700hp/700tq I believe, and it has Brass Guides for the 1,2 Fork and the 3,4 Fork, Steel 3-4 Fork, Carbon Fiber Blocker Rings, Billet 3-4 Keys, ontop of the fact that it's pretty much a brand new Transmission.
I would love to have the T6060 Ratios, but I think mine will work good for the low cost of $1950.
Old Oct 8, 2008 | 03:47 PM
timelord's Avatar
I guess I will pick up the Z06 and store it until I find a LS6 or 7 to drop into it,,,,,
Thanks for the info guys!!
Old Oct 8, 2008 | 04:06 PM
Grr's Avatar
Grr
im tellin ya, your gonna have to buy certain parts regardless, like wiring, ECM, etc. I would honestly go pick up a 5.3 from a salvage yard for $3-400 and piece the rest onto it. Otherwise you can get a standard vette LS1 swung in there for cheap. I wouldnt worry about finding a LS6 or LS7, just get whats cheap and mod it later, youll be alot happier.
Old Oct 8, 2008 | 04:18 PM
timelord's Avatar
LS1 would definetely be an option,,,,,
Old Oct 8, 2008 | 04:25 PM
Formula350's Avatar
Assuming it's just Less Motor, then he shouldn't really need any wiring or PCM for it. Even if it's a truck motor. Frankenstein is basically just what you said though, a truck motor, but a step further with better heads and any other stock parts. Like anyone with a Vette LS2 or 6 that upgraded cams, you'd be able to put that into any motor and have a very nice upgrade!
Old Oct 8, 2008 | 04:28 PM
BlacKBirD25's Avatar
i hear u on that one man.. broke mine twice now
Old Oct 8, 2008 | 08:43 PM
the_merv's Avatar
I've gone through 4 different builds.. it's the spinning down-shift when I get on it to pass someone..it'll break loose as it's downshifting, hit the tach a couple of times, then shift up, and then later the Tranny's comin apart..
Any Gen III Engine Longblock will go directly into that car without any modifications.
I'd build me a little LS1 383 Stroker and get a Cam in it, LS6 Heads and Intake, and tear some **** up..
