Which TB for a 398 stroker?? 52 or 58
Old Oct 10, 2008 | 12:18 PM
Abdullah's Avatar
for the 398 LT1 you have go with a 58mm TB and even a monoblade TB if you can. throttle body size doesn't hurt the motor's performance and even ported intake manifold doesn't hurt, it is the heads that have been over-ported will hurt performance.
but you have to tune after you install either the 58mm TB or the monoblade TB.
Old Oct 10, 2008 | 01:03 PM
jarretthise's Avatar
Originally Posted by LittleRedZ
i've made 725rwhp through a 52mm and unported stock manifold through a th400 and 9" rear, when pushing air into the intake it dosent hurt that much but when sucking on N/A motor you want to suck as much air as possible.
and i would assume you could be making a little more power if you had your intake ported and polished to 58mm!! i could be wrong, dont know what setup your running so.
as for your ? though i would have to say 58mm...thats the logical way to go..
Old Oct 10, 2008 | 02:15 PM
slomarao's Avatar
id say 58mm. monoblade if you have big plans/deep pockets.
