Need opioins?
Old Oct 25, 2008 | 06:06 PM
fauslpss's Avatar
Default Need opioins?
Did the drill mod and replaced the clutch I doesnt sound like theres any air coming out of the bleeder. I has a fair peddle after pumping after I crack the bleeder screw I have to pump it back up agian to get a peddle. Ive worked on this for a hour and used 16oz of fluid, Do I need to mighty vac it or does it need a shim. It worked fine before I tore it down?!
Thanks Eric
Old Oct 25, 2008 | 06:31 PM
TranzAmMan's Avatar
Its normal that you have to pump the clutch to get it back up after cracking the bleeder screw. But what is you clutch doing, chattering, not engaging, not disengaging?
Old Oct 25, 2008 | 07:15 PM
fauslpss's Avatar
No its a new clutch I havnt even been able to drive it bc I cant get it into gear I got everything back together and Ive been trying to bleed it.
Old Oct 26, 2008 | 03:18 PM
fauslpss's Avatar
Mityvac'd it, its getting better but not perfect.....
Old Oct 27, 2008 | 07:48 PM
fauslpss's Avatar
It goes in 1 in every 10 attempts it has a peddle but wont disengage is this a problem a adj master will fix or is there somewhere else I should look??????
Thanks Eric
Old Oct 29, 2008 | 06:37 PM
fauslpss's Avatar
Made the master adj so it works now.
