Quick Time Bellhousing
Old Nov 8, 2008 | 09:57 PM
myws61's Avatar
Default Quick Time Bellhousing
I recently purchased an sfi approved bellhousing from Quick Time Inc. It was supposed to be the best fitting one for the camaro. I had few problems the biggest being that i had to cut a large chunk out of the side where the bleeder screw was, because it would overlap and you couldn't get a wrench on it no matter whether you had the access hole or not. The only other problem was that the dowel holes did not line up perfectly and i was forced to drill them out slightly. Other then that I would recommend it. Its a very nice piece and I would recommend it.
Old Nov 9, 2008 | 11:34 PM
Dark Shadow's Avatar
****!!!! i wouldnt buy it if i had to do all that work. you should have called and got a new one
Old Nov 10, 2008 | 12:12 AM
Josh@MASPORT's Avatar
Closed Sponsor Account
ive done the same thing to any ive installed
Old Nov 10, 2008 | 06:32 PM
DAVESS02's Avatar
For the $$ paid for these parts, they should fit perfectly. From what I've read about the other bell housing out there, it shouldnt even be on the market.
Old Nov 11, 2008 | 10:47 PM
John02SS's Avatar
Mine fit perfect. You have one of the first runs where the slave and master holes didn't line up. A few fitment issues early on, but the later stuff was on the money.
