Clutch pressure
Second shifts smooth, and I have full clutch pressure when I release from shifting into second. But when I go to shift into 3rd, it bounces right off 3rd, no grinding, it just doesn't go in, and I loose all clutch pressure. The pedal sticks to the floor and I have to pull it up with my foot, then I only have about 1/2 pedal, and it won't go into gear until I coast for awhile. It's hard to shift for about a min or two, then it's normal again.
I did the drill mod, replaced the MC, and put all new clutch fluid in. Where else am I having an issue?
SLP 1 3/4" lts, catted ypipe, corsa cat back, slp flow pac, summit ud pulley, sfc's, and some rear suspesion, I've got mt 315's out back, but it did this on the stock tires so that doesn't have anything to do with that.
I've got a new LS7/LS2 clutch/flywheel waiting to be put in, but I've been told that I could possibly have a bent 3/4 shift fork, and if that's the case I only want to pull the tranny once and fix everything then. But if it's a bent fork then why am I loosing pressure.
I'm hoping that when I do get around to replacing my clutch and slave that takes care of the issue. I was just wanting to make sure that there wasn't anything else wrong.
