Running 4 speed behind LSx engine????HELP!
Old Nov 20, 2008 | 10:12 PM
twin74s's Avatar
Default Running 4 speed behind LSx engine????HELP!
Can it or has it been done? If so can someone point me in the direction of a right up or anything? Wanting to put a LQ9 in a older chevy pickup with a 4 speed.
Anyone got any help on this?
Thank David
Old Nov 20, 2008 | 10:32 PM
thesource's Avatar
Its not hard at all . The LSX shares all the common bolt holes on the bolt pattern except for 1 . You simply do not use that 1 bolt and it will be fine . The biggest thing to remember is the older GM bellhousings had a passenger car version and a truck version . The hole for the bearing retainer was different in size . If you plan on using a "car" style transmission , be sure to get the correct bellhousing for a car and not a truck . Clutch wise , it depends on how you are setting it up . If you plan on using the original style clutch linkages , you can use an LSX clutch kit and adjust the linkages to where the throw out bearing releases the clutch at the correct time . Its really simple to do and is no different than any other after market style clutch kit . You will also need to reuse the LSX flywheel .
