High RPM 3-4 Shift problem
Old Nov 26, 2008 | 01:58 AM
99nbmbird650's Avatar
Default High RPM 3-4 Shift problem
Im having a problem, when i got my car back with the new motor my clutch pedal did not stick as it did before with just bolt ons, the shop upgraded the slave cylinder. But when i drive my car every gear works perfectly fine but any gear after 3 like 3-4 it doesnt want to go and 4-5 at high rpm also doesnt like to go in at high rpm and my clutch just started to stick again. Any advice will be greatly appreciated.
Old Nov 26, 2008 | 02:12 AM
getusum's Avatar
Call Tick and get their MC and clutch line.....Check your fluid, bleed the clutch..Make sure you did all the check list stuff..
