is this bad?
Old Nov 27, 2008 | 12:44 PM
camarokid239's Avatar
Default is this bad?
well iv been having trouble with my cluth so i looked at the hydrolic line n when i went to go touch the end of the line that is attached to the tranny it is really lose n wiggles is this bad?
Old Nov 27, 2008 | 01:14 PM
beezer1519's Avatar
is your clutch working fine? and yes there is play in the line
Old Nov 27, 2008 | 01:20 PM
well i raped the line cuz it was gettin hot and the fluid would burnin so i checked n i didnt know if it was leaking maybe. but hopefully raping the line fixed the problem.
Old Nov 27, 2008 | 01:39 PM
beezer1519's Avatar
yes common problem when you have lt's the line sits so close to the collector that it boils the fluid... hopefully wraping the line helps
Old Nov 27, 2008 | 01:44 PM
o my bad the reason y i had to rap it was cuz it wasn't shifting into 3rd and every other gear.guessing the long tubes were getting really hot
Old Nov 27, 2008 | 01:48 PM
beezer1519's Avatar
yes fluid boils making air in the system... causing the pedal to be spongie and not disengage all the time... did you only have problems with third? or you were having problems with every gear?
Old Nov 27, 2008 | 02:09 PM
well its a lil tough in 3rd then it starts grinding with the rest of the gears. i dont know what to do..
Old Nov 27, 2008 | 02:15 PM
beezer1519's Avatar
if it's grinding in all gears it's hydraulic/clutch specific hopefully wrapping the line fixed it... did you bleed it after??? as there is probably air in the system already...
Old Nov 28, 2008 | 01:14 PM
well i bleed it bout a couple months ago n the problem never went away so figured it was something else
