Major Clutch Problem LT1
Last night I was driving away from my house and I was coming up to a stop sign so i disengaged the clutch. As soon as it was halfway out I heard a loud thud come from infront of the tranny area and my clutch slammed to the floor then my car shut off immideatly. it took a little bit for the clutch pedal to come back up, but wen it did, it was very very stiff. i tried to start the car up again but it wouldnt even crank. The tranny was able to shift into neutral and i was able to push it out of the road.
What im thinking is that something broke off the clutch and whatever broke is jamming the flywheel so it cant turn over and at the same time the clutch is always engaged.
when i turn the key it clicks and the engine will move but not much.
people are telling me that it could be the pressure plate and others are telling me its the throwout bearing (dont know what that is).
I could use all the help i could get right now. thx.
Replace ALL the hydraulics - bench bleed eveything seperately, then again on assembly of the two cylinders; you might as well do the line mod too while you're at it.
Call Fred Beans and order an 96 Vette LT4 clutch NOT a Kevlar SPEC 3+ unit (Yeah, burned thru two of those - one in less than 3 months - cr&p IMHO) and call it done!
i wish i could pull the tranny out myself and learn but no time...got school, work, fam, gf... not enough hours in the day. ima have to take it to a shop...
can anybody recomend some good aftermarked slave?
1994Z28LT1- good times, huh... lol.
http://shop.oreillyauto.com/ProductD...pe=244&PTSet=A
hope fully they'll find the problem soon.
in the meantime, what clutch would be the most cost effective in terms of reliability, drivability and longetivty for an LT1 that is a DD and is raced 3 times a month at the most?
the only reason i ask is because all the threads i seen so far are for LS cars.
http://www.autozone.com/R,2174272/ve...ductDetail.htm
Regardless, my GM LT4 unit does have springs, it is smooth as stock, but compared back to back with an LT1, they do infact look different.
