Reuse PP?
Old Dec 8, 2008 | 01:46 AM
transamws6_97's Avatar
Default Reuse PP?
I have 35k on my spec 2 and it is just starting to slip. Since I'm rebuilding the motor might as well put a new clutch in. Since I am building a new motor I'm trying to keep everything on a decent budget. I was looking at getting a spec 2+ disk and a new flywheel from autozone and arp flywheel bolts but my question is can I reuse my spec 2 pressure plate that i've had for 35k miles
Old Dec 8, 2008 | 05:38 AM
LS1-450's Avatar
General rule is that the flywheel can be machined & re-used one time. So, you can have it re-surfaced & used. I am not sure about the minimum thickness requirement, but recall that anything over 0.815" after re-surfacing is OK. Hopefully, someone will confirm this.
Have the flywheel & new pressure plate balanced as an assembly after the flywheel has been re-surfaced.
Old Dec 8, 2008 | 07:42 AM
bb5401000's Avatar
You can, but shouldn't use the old pressure plate. After 35,000 miles, the springs or "fingers" have lost their original tensile strength and cannot push the clutch plate against the flyweel as forcefully as when new. Also, you want a nice smooth pressure plate for the same reasons you resurface your flywheel. It's like replacing your brake pads without machining the rotors. You can do it, but it's not a good practice.
Old Dec 8, 2008 | 07:47 AM
CBCCI's Avatar
Closed ex-Sponsor Account
Default Pressure plate
Yes you can reuse a pressure plate, but you will probably not get the performance that youexpect out of it. The fingers do eventually get weak and your release will change. I do not think that this will be the case at 35k, but it probably will be the case by the time the second disc wears out.
Also I agree in part with LS1-450 to save money if your flywheel has not ever been resurfaced, you might consider getting the thickness checked on that and maybe use the money you would save on a new flywheel to buy a new pressure plate.
Old Dec 8, 2008 | 09:09 AM
LS1-450's Avatar
Duh??? I got caught up in commenting about the flywheel & balancing, then completely for got to answer the PP question. Appologies; & fortuneately for me, these guys got you covered on the PP. Good-luck
