Problem with 6th gear
How many miles on the trans, when was the last fluid change, and has 6th ever given trouble in the past?
Luckily that work can happen with the trans in the car if needed, and shouldn't require reshimming. If it has ~170K miles on it though, you might want to drop it and freshen it up completely..
(Looks like you're only 75mi from Tick, so give Joey a call if you're not sure you can DIY..)
