bleeding the clutch hyd.
Old Sep 29, 2003 | 03:12 PM
StangSlayerSS's Avatar
Default bleeding the clutch hyd.
I pulled my Trans out and had it rebuit. i dissconected the master form the slave cylinder will i have the bleed the hydraulics all over again or should it all be fine .
Old Sep 29, 2003 | 10:56 PM
felton316's Avatar
Default Re: bleeding the clutch hyd.
Should be fine as long as no air entered the system. If you just undid the quick connect you should be fine.
Old Sep 30, 2003 | 07:17 PM
Thanks for the info
