Grinding issue....
I get it into my car and now it grinds EVERY time going into 4th if i shift quickly. The only time that it doesnt grind is if I hold the clutch in.. let the stuipd transmission stop .. then shift.I dont understand it.. the transmission worked fine. My friend with a standard m6 beats the **** out of his and has 0 issues. I double checked to make sure the slave was bled and I made sure I am pushing the master far enough and everything is good. The clutch releases at a nice point about 3/4 from the top. I am using syncromesh for fluid. I have no reason to think its anything but a bad syncro but cant understand why one would be fine in one car and grind badly in another.... all other gears are fine.
