Hey guys please help..
Old Jan 17, 2009 | 09:12 PM
charlie c5's Avatar
Default Hey guys please help..
Im workinng on a 2002 WS6 m6. I swapped the Spahn Torque are for the BMR adjustable torque arm. I pulled the drive shaft to make all of this a bit easier. I put everything back together pretty easily. Took the car for a drive and now for some reason, I have to use some muscle to put the car in reverse, and my speedo isnt working now. Any ideas... Thanks guys..
Charlie
Old Jan 17, 2009 | 09:29 PM
DAVESS02's Avatar
Electrical plugs in the right spot on the trans?
Old Jan 17, 2009 | 09:30 PM
charlie c5's Avatar
Ill go look. would that have anything to do with me needing to use some muscle to put the car in reverse.
Old Jan 17, 2009 | 09:36 PM
rollinna65's Avatar
Sounds like you disconnected the two sensors on the passenger side of the trans. Those are the reverse lockout and the speed sensor (I believe). If those aren't plugged in you wouldn't have a working speedometer and it would be a real bitch to get into reverse.
Old Jan 17, 2009 | 09:53 PM
charlie c5's Avatar
Yup I crushed the damn sensor on the drivers side. I dont see how I COULNT have. The BMR arm where it goes into the mounting clam shell bracket goes right into the sensor..... now what am I gonna do..???
Old Jan 19, 2009 | 03:48 PM
charlie c5's Avatar
I looked and saw that I crushed the connector to the sensor thats rights behind the clam shell clamp for the torque arm on the tranny. I replaced it and the speedo works now.. Its still a little hard to put the car into reverse. Just started when I swapped the torque arm. The tranny is new. Less then 2ooo miles on it....
