Gears or Rear end?
If so it will help save your rear, cus they have problems holding a stock motor!
You can still pop that rear though so maybe be easy on it till the 12'er?
The higher gear will help alot, & match your power band w/ the cam much better.
Then with the 12 bolt you can do the high rpm clutch dump of death!!
Appreciate your input.
Just take it easy on the stocker for a bit.
