no 6th gear
Gadzooks!!
I agree with 85MikeTPI that the clutching teeth on the 6th drive gear are probably damaged. We stock and sell all the parts for the your trans. Replacing 6th gear does not require a complete teardown. You can download the Shop Manual from our website. Recommend that you do a partial teardown before ordering parts.
Don
Other thought would be if both the 5/6 fork was bent, and has missing pads, but even then it should have slight engagement.
Does the shifter handle feel that it moves into 6th, as deep as it does into 2nd and 4th?
haha....fellow preston and steve listener huh?
true..for now ill pull the tail and see what exactly it looks like. go from there...might just do 6th and syncro and fresh fluid for now...do a full rebuild when i have cash
and 85mike...you have experience in rebuilding these??
thanks all
Yeah, saw you were from warminster, thought you might listen..
