Second Gear Question
Old Jan 26, 2009 | 10:37 PM
1sicss's Avatar
Default Second Gear Question
O.K I have 1998 Camaro Z28 6-speed everytime I turn the car on and take off, when I shift the car to 2nd the shifter seems to have some trouble getting into 2nd almost like a grinding sensation or sometimes it grinds and I have to take it out of gear right away. Once I have been driving the car for a little the problem goes away. What could this be?
Old Jan 27, 2009 | 06:36 AM
85MikeTPI's Avatar
If you live in a colder region, it could just be the fluid isn't allowing the friction rings to fully do their job. Does it happen if you let the car idle/warm in neutral? If it's only 2nd that it's happening in, it's probably the 2nd gear blocker is wearing quicker than the rest, and the cold fluid is highlighting the wear.
