flywheel question
Old Feb 2, 2009 | 07:51 PM
sepno77's Avatar
Default flywheel question
how many times can a flywheel be resurfaced?
do they go bad?
dose anyone have a part # for the stock flywheel?
is it possible that the fly wheel to cause a clutch disce to go bad?
do clutchs normally last for just a 1-2 years? cause mine last me for a lil more than a year and i have to change it again. last clutch was a spec 2
Old Feb 2, 2009 | 08:02 PM
Benner's Avatar
I've always been told to only surface once and that's only if your still within tolerances.
Yes they can go bad. A tell tale sign is heat spotting. If there's alot of blue heat spots I've always been told to just replace it.
Yes a bent or warped, or even burnt flywheel can cause a clutch to burn up or even break in some extreme cases.
My stock clutch had 114,000 miles on it. Most of that time was while the engine was built.
Old Feb 3, 2009 | 01:26 PM
sepno77's Avatar
thank you very much for answering my questions, Benner
Dose anyone know the part # stock clutch or best place to buy one at?
Old Feb 3, 2009 | 03:21 PM
Benner's Avatar
GM# 12581650
Looks like from dealers you can only buy as an entire clutch assembly kit.
Price for that at my dealer is $656.
Edit. gmpartsdirect.com has the LS1 kit for $389
You'd be better off going LS7 clutch and LS2 flywheel for cheaper than that. Mine was around $450 if I remember right.
Old Feb 3, 2009 | 03:59 PM
sepno77's Avatar
Originally Posted by Benner
GM# 12581650
my car is a 1993 camaro z28 lt1 not lsx
Old Feb 3, 2009 | 05:05 PM
Benner's Avatar
My bad. I should've paid more attention. The dealer I call is closed now. Any dealer should be able to at least give you a part number.
Old Feb 3, 2009 | 06:50 PM
sepno77's Avatar
what do u think?
http://store.summitracing.com/partde...rt=ZZZ-50-6525
Old Feb 3, 2009 | 07:21 PM
Benner's Avatar
I would think it'd be sufficient.
Old Feb 4, 2009 | 02:05 PM
sepno77's Avatar
thanks again for all ur help benner
