Clutch help
Did H/C/I on the car along with a Spec 2+ with alum flywheel, new slave, new adj master. THE SPEC SHIM IS IN
I can shift fine with the engine off, but with it running it is hard to get into every gear. Reverse takes a lot of pressure and makes a clunking sound when it goes in. While driving it is harder than normal to shift and feels extremely notchy It helps to blip the throttle some when up and down shifting.
The clutch is not releasing, when stopped in gear and clutch pressed in car will move at around 5K rpm. I have bled the system and all the fluid is new. I have also tried adjusting the master, but that has not seamed to fix anything.
PLEASE HELP ME !!!.
