Tick bleeder line issue
Old Feb 13, 2009 | 12:44 AM
W8N2SQZ's Avatar
Default Tick bleeder line issue
Has anyone had an issue with the Tick bleeder line leaking at the slave?
I installed in dry and cranked on it and the sucker leaked.
Anyone else out there?
Thanks,
Glenn
Old Feb 13, 2009 | 08:22 AM
Gen414's Avatar
Thanks,
Glenn
I do not have mine yet, but I am pretty sure it is pipe thread, right? If so, you can not install it dry...get you some plumbers thread paste, or teflon tape. I personally like the paste myself.
Old Feb 13, 2009 | 08:25 AM
Jonathan@Tick's Avatar
LS1TECH Sponsor
Do you have the one that seals with a washer, or the earlier style that seals exactly as the factory bleeder? Originally, we had custom fittings made to seal on the seat of the slave to seal just as the factory bleeder did. The threads however went down farther than the factory bleeder, and I installed one into a used slave that leaked. I think what happened is the used slave had some gunk built up inside at the threaded area near the bottom of the hole.
Since then, we've went to a washer type seal with a shorter fitting. We couldn't order enough volume to keep making the custom fittings, and the shorter fitting should fix the sealing issue for anyone that is re-using an old slave.
As long as you put the washer between the slave and the fitting, you shouldn't be having any problems with the new style. Just let me know what you've got and we'll send you out another line if needed.
-Jonathan
Old Feb 13, 2009 | 08:29 AM
LS1TECH Sponsor
It uses a 10mm thread and a brass washer to seal it to the slave like is typically used between a brake hose and caliper. Some teflon paste probably wouldn't hurt, I just haven't had any to leak.
Old Feb 13, 2009 | 11:03 AM
hj99Z's Avatar
What fluid do you guys recommend for the tick master? I am still running dot3 and had it boil on me once. Alright to use castrol DOT4?
Old Feb 13, 2009 | 01:35 PM
Gen414's Avatar
Ahhh ha, I see. I gotcha. With the washer there, I would not see the need for teh paste like I was suggesting. I was thinking it was straight pipe thread, and with that setup, you HAVE to use tape or paste. AN fittings no thread/paste. or inverted flare, no paste/tape either.
Old Feb 16, 2009 | 08:54 AM
W8N2SQZ's Avatar
Thanks for the advice everyone.
Jonathan,
I must have the older style than because the fitting is long and has the same tapered tip as the stock bleeder fitting and there was no washer.
The inside of the slave is clean for the most part and no debris. I used a black marker and inked up the tip of the bleeder line fitting and ran the fitting down and cranked on it, than I pulled it out and noticed that the contact patten from the ink was very small compared to the slightly worn in contact pattern of the stock bleeder fitting.
After comparing the angle of the head on the stock fitting and the bleeder line fitting, I noticed that the bleeder line has more angle than the stock fitting.
When would you be able to send out another line?
Thanks,
Glenn
Old Feb 16, 2009 | 07:24 PM
LS1TECH Sponsor
Glenn, just give us a call sometime tomorrow and Joey will get you taken care of. Sorry for the trouble.
