LS7 clutch on a LS1
Old Feb 17, 2009 | 07:53 PM
Greg Pippin's Avatar
Default LS7 clutch on a LS1
ive been playing around on the computer at work in the parts dept. The computer says that GM part# 12571611 is for the LS7 pp, clutch disk, and flywheel. its the whole kit.
I have also found on the internet that people are selling part#12571611 as only the flywheel, and GM part# 24238412 as the pressure plate and clutch disk.
And some people say that you cant use the LS7 pressure plate on a ls1....
I am so confused....
Will someone please clarify this for me, because i want to use the LS7 set up on my 2000 T/A.
Thanks.
Old Feb 17, 2009 | 09:04 PM
pontiac455cars's Avatar
You can run the ls7 clutch,you have to run the ls2 flywheel.I have the part #'s at work.I installed one in my 01 t/a.It works fine.I have a d1 procharger with no slip.your year model slave will work.
Old Feb 18, 2009 | 04:57 AM
badazz99ta's Avatar
if your gonna go ahead and get a new clutch, i would replace your master and slave cylinder. do it right the first time.
Old Feb 18, 2009 | 06:46 AM
oberth1's Avatar
you can also run the ls6 Clutch package. I found them to be much cheaper and without any major upgrades you should be fine with that. Bolts right in and under $300 complete shipped.
Old Feb 18, 2009 | 09:25 AM
ghettocruiser's Avatar
Right now scoggin dickey has free shipping on a bunch of stuff...including the LS7 clutch package. Everything you need, in one package, at a pretty much unbeatable price. $459.99 SHIPPED... Cant really beat that.
I ordered mine from SD and was not disappointed. Fast shipping, helpful customer service, came with the new bolts and all. Grab a GM slave cylinder from them also..since the trans it out, no better time to replace. The LS7 clutch so far has performed great. Awesome street manners, grabs great, and installed without a hitch.
J.
Old Feb 18, 2009 | 09:31 AM
deelong4002's Avatar
Do you have to shim the LS7 clutch upon install?
Old Feb 18, 2009 | 09:42 AM
I didnt shim anything. I installed it straight up with a new slave. After the break in, it drove great... however Im installing a TICK master cylinder (now on group purchase ) to make sure everything is working as its supposed to. I have slightly notchier shifts than I did with my spec...but my spec was pretty beat.
J.
Old Feb 18, 2009 | 11:03 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Greg I was running the LS7 setup in my TA, so if you got any questions shoot me a PM
Old Feb 18, 2009 | 11:13 AM
BIG_MIKE2005's Avatar
NO NO NO, LOL.
No tryin to be a dick but this has been covered so many times it's not funny. The LS7 clutch kit for the LS1 f-body comes complete with LS2 flywheel. If your gonna run the LS7 clutch you MUST use a LS2 flywheel. No shims or tricks to install. Just swap it out for the old stocker, stab the tranny back in & bleed it.
It's a very easy & straight forward install.
Old Feb 18, 2009 | 07:11 PM
Im going to do cam, heads, and a little bit of nitrous.
Old Feb 19, 2009 | 07:42 AM
yellowjacketfever's Avatar
got mine from gmpartshouse from gene for the complete kit, including the pilot bearing for 389.00 shipped... now i need to no if there is a reputable shop that will put it in my gto for me. i do not have time to do it myself. i was told about simple quick raceing, anyone know much about them. i am currently at 399whp and 389 wtq on the stock clutch and it is fadeing real fast after a year of modding. i live in ardmore ok. so any help would be much appreciated... thanks...
Old Feb 19, 2009 | 11:27 AM
Man I'm not sure about shop quality in your area. there is a good place in OKC & one here in Tulsa but Oklahoma is lacking in LS performance shops.
Old Feb 19, 2009 | 11:52 AM
yea i no! i can take it to able raceing in midwest city ok. they are the ones who did my car to begin with. just are a little to high on the clutch work. 700$ to put in a clutch...
Old Feb 21, 2009 | 01:30 AM
2002ssowner's Avatar
Abel racing told me they'd do a spec2+ for ~1100$ in my 2002 ss camaro. i ended up doing it myself ended up around $650 inc new slave and tob and pilot. I am goign to get it tuned there in the next few weeks though. im not saying there not a decent shop but pricey,, yes
Old Feb 27, 2009 | 01:54 PM
metalmechanic's Avatar
Scoggins Dickey sold me the complete setup as an LS 7, Fly, clutch,pressplate ,masrter slave, to/b works great, at the time for around $575. shipped
Old Feb 7, 2014 | 08:52 AM
camarozz383's Avatar
same question for me guys, will 12576711 work on my 5.3 with a t-56 trans? or is there something else I need to know, wish I could find a sticky!!
Old Feb 11, 2014 | 06:45 AM
rickybobbyss's Avatar
You can get ls7 clutch and pressure plate from summit racing and order a gto flywheel from rock auto..that would be the lowest price for a ls1/ls7 clutch kit
Old Feb 11, 2014 | 06:50 AM
I'm not sure if this stuff fits a 5.3 I'm sure someone will know the specifics
Old Sep 30, 2021 | 09:31 AM
Isaac9289's Avatar
Default Having disengagement issues
hey man I’m having disengagement issues I replaced the master cylinder checked the throwout bearing distance still can’t get the car into gear well it started. I’m using the luk ls7 kit any advice?
