Flywheel? steel or chromoly?
I have an aluminum Fidanza which is about 13 pounds if I remember correctly and the lighter flywheel will make the engine rev faster, but not launch as hard because you don't have that inertia of the weight spinning. Basically, unless you are launching at or near the rev limiter and still bogging the extra weight isn't helping you out and is hurting you. The only time you want that extra weight is when you are launching and getting plenty of traction. That said, if you are launching on slicks you probably want that extra weight. Lightweight is fine to drive on the street. Sorry, I can't speak on the strength, reliability and longevity of the chromeoly but I doubt you would have a problem there.
