Are any of these gears trashed?
Old Feb 26, 2009 | 07:28 PM
sschoeffler's Avatar
Default Are any of these gears trashed?
Rebuilding my T-56. Do I need to replace any of these gears?
Old Feb 26, 2009 | 07:46 PM
bearcatt's Avatar
I'm not an expert but I'm learning.
Overall your gears look ok. A little side wear on the counter shaft cluster, but normal.
A couple of you syncro assemblies need to be replaced.
Your billet keys look about shot.
Overall not to bad. IMO ... Looks like a basic rebuild.
Old Feb 26, 2009 | 10:04 PM
Gen414's Avatar
Looks like in maybe 3rd or 4th picture, a slider has some hairline cracks in it
Old Feb 26, 2009 | 11:36 PM
twelver12's Avatar
from those pics the gears look fine why is it that you had it apart? and while its apart replace your blocker rings (synchros) and hub keys
Old Feb 27, 2009 | 06:40 AM
calhoon's Avatar
The gear teeth are fine but the clutching teeth are not. Isee at least two fractures struts(inserts) and the sleeve clutch teeth are worn. It would appear that either shifts were missed regularly or the clutch did not release properly . It doesn't matter which the damage is there.
